Hi, I am working on building a computer with a Core Duo T2300 processor (original thread here). I have some experience installing HSFs, but because this processor has no heat spreader, I am wary. I have not been able to find *ANY* information on how install the HSF on this processor. I have pics if the relevant components:
The HSF and backplate
The HSF from the side
Processor
Motherboard
Can anyone explain to me the proper method of installing this HSF? It looks like the screws on the for corners have two different threaded sections, and that if you screw down too much, the screw will run out of threads and the spring will push back up. Is this the mechanism for keeping too much pressure off the CPU die?
Sorry if this is obvious, I have not run into this type of retention system before, and I have killed chips by crushing the core before, so I am paranoid.
Processor
Motherboard
