Hi all
I have a BenQ W500 projector that can take an input of 1080p and downscale it to 720p. I would like my computers videocard to display at 1080p and let my projector downscale it, but the highest resolution according to the computer is 1280x1024. The videocard is an 8400gs with a max resolution of 2048 x 1536, so it should be able to do 1080p for my movies.
Should I install a different monitor driver and increase the resolution; if so what driver do you suggest? I tried powerstrip, but it wont even let me go into advanced settings to change the resolution.
