JAW said:Running a p4 3.0ghz HT, standard 5.02 install. I heard there are different flags to use for p4s? What are these and how will they help? Also I am only running one instance, should I be running two?
HoosierDad said:I think 2 instances help somewhat.
BillR said:The best answer of course is more Boxen. Everything else seems to be right with the one you have.
I use to have one box, once upon a time. Then I met relic![]()
