Not knowing anything about bus speed, how is it, or is it possible to increase my bus speed? Currently I'm getting 233 MHz, which I assume is pretty weak.
umm... if its a compaq, i doubt its possible, becuase the fsb is usually locked on compaqs, dells, etc. if you really want to overclock it, i would suggest buying a new motherboard, or getting some program like cpufsb or clockgen.
if you want to try it though, go into your bios and see if its available to change the cpu frequency.
