Specs: Asus A8N32-SLI Motherboard
Processor: Opteron 165
Stepping: 0543
RAM: Mushkin Redline PC4000 2GB Kit
Video: 7800GT OC
Cooling: Stock
Current settings:
FSB: 275Mhz @ 3-3-2-8 - 2.8v
Core Speed: 2475Mhz
Multiplier: 9x
LDT/FSB: 4X
Voltage: Stock @ 1.35v
FSB
RAM CPU/14
I know the opterons are capable of 2.7ghz easily im only at 2.4ghz any recommendations on what I should change or adjust?
Side Note: On CPU-Z my memory frequency is showing 176.8Mhz so Im assuming im using a the board automatically set a memory divider in for me. Im normally O/C with a DFI board and new to Asus boards. My question is if the memory frequency is only at 177 and the memory is capable at a standard of 250mhz should i be changing the memory divider to 1:1? how should i have the settings to achieve best oc results?
Stepping: 0543
Video: 7800GT OC
Cooling: Stock
Current settings:
Core Speed: 2475Mhz
Multiplier: 9x
LDT/FSB: 4X
FSB
