Basically the wires inside my computer are a mess at times. Wires need to be tucked away and routed. One problem I kept running into was places to tuck the wires so they would be out of the way. Case fans in particular seem to be the hardest to manage, especially the one in the window of the pc. I need to come up with a good way to route that wire.
The only thing I can think of to use are those wire clips that have that sticky backing on them so they can be mounted to what ever. My problem has been trying to locate some SMALL ones that would work with the tiny fan wires. Has anyone found a good source for them? I can find the larger ones.. but I need some that are as small as possible.
