I've been answering quite a lot of questions on this forum, and I keep asking for the same things, so this is what I need from you, if there is a problem you need help with:
Note: Anywhere I say C:\windows or C:\documents and settings, substitute the directory's name if you renamed them, or installed to a different drive
1. If it's a crash or bluescreen please post the dump files somewhere I can get at them.
a) Bluescreen dumps are stored in C:\windows\minidump
i) If you have full dumps set up it's stored at C:\windows\memory.dmp
b) Crash dumps are stored at:
C:\Documents and Settings\All Users\Application Data\Microsoft\Dr Watson\user.dmp
i) Unless you changed the path by running drwtsn32
2. Notify up front any tweaking or changed you have made.
a) Services turned off
b) Pagefile turned off
c) OverClocking
d) Etc. More Information the better
3. If you are running an illegitimate copy of Windows, don't bother asking for help.
a) If you are trying to bypass security features, Don't Ask
4. I work full time, and have a life outside of work, so don't be suprised if I don't answer right away.
5. I can't help with crashes that aren't windows based, as I only work on Windows.
Windows Setup To be exact. Edit: I now work in the Security Business Technology Unit
Edit tk 2: I'm now a cybersecurity consultant with Microsoft Consulting Services.
The above post is my personal views and opinions, not that of my employer.
This posting is provided "AS IS" with no warranties, and confers no rights.
Mods: If you disagree with this message feel free and delete it, I'm just trying to speed up the diagnosing of problems.
c) OverClocking
