First, let me apologize for making yet another thread that has to do with ESD. But it seemed to me like the best way to get some needed information. Please don't make this into a discussion about whether or not ESD is real.
People say you should ground a computer case when working inside so that a potentially harmful discharge between person and case can go to ground instead of the computer components (that’s what I understand of it anyway). To do this people recommend leaving the PSU plugged in. But what if you have to swap your PSU? If you disconnect it, the ground is gone and components are more vulnerable to ESD (if I understand it correctly). Would it be a good idea to use a separate wire to ground the case? And could this be used as a full alternative to keeping the PSU plugged in while working inside?
To ground the case I would use a wire like this, attach its ring to the case with a screw at the back and connect its plug to an earth bonding point like this.
But is that really a sound thing to do, is it safe? Can I use both this wire and PSU at the same time (even while the computer is running), or will this create problems? I’m not all that comfortable with strapping a wire to my case.
Regards.
Regards.
