How to get P160 bezel off?
stultus
Please don't laugh (long), but how do you get the front bezel off the P160?
I've taken off the window panel (which makes this horrific snapping noise before being able to open the whole 90 degrees). I'm not sure if I should be brute forcing this, or fiddling with those green things. The manual says to start at the bottom, but the green thing on the far side of the case is completely inaccessible. I don't really want to break my new case. What's the trick? :confused:
Well I just looked at the manual and it says to start at the bottom and swing upward. But doesn't say how to to it. It looks like a manual written in Chinese translated by a computer case illiterate person to English. Good luck.
I just built a P160W computer yesterday and here's what i figured out:
Make sure the left (windowed or lock-able) side panel is off. Then pull on the bottom of the bezel away from the case. It should then just pop off and then it'll slide down a bit to pull the thing off all the way. It is there that you will be able to undo the thumbscrews that hold the right side panel on. I almost broke the right side panel by prying it off, luckily I figured out the thumbscrews under the bezel just before I went for the final/rage yank of death. Whew!
Hope that helps.
