no xpVista?
He was suggesting you upgrade to Vista. I could be wrong here but XP supports to DX 9 and no higher from what I have gathered.
i didnt really look into it lol but thankks for letting me know !Very. You /must/ run Vista for DX10 support. I find it hard to believe you didn't know this when you bought the card if you're even sort of active on these boards...
If you have your serial then I think you can use any disk to legally install the game.
Installing it isnt the problem its when i have to give the cd back to my friend. What will i play with ? feel me ? IM thinking is there a way i can run an iso or soemthing>
Copy it.
from what they tel me is that if i copy the cd ea can find out and ban your cdkey
Yeah, that's bull. So long as your 'run' CD is original that's not going to happen. Period.
so ur saying that i can just copy my friends cd and play off that ?
theres somthing called ea links where i can just dl the game but i have no idea how toDownload PowerISO and make an ISO image file of it. Mount it to a virtual drive whenever you want to play it.
Vista must be had to unleash the POWAH of DX10.
