We've all been there, you have a legitimate transient network failure within comcast's network, usually after the first couple of hops resulting in a stream of packet loss or other undesirables outside of your control. However if you attempt to call support of course you'll spend the next few hours rebooting your modem incessantly, screwing and unscrewing the coax cable, having them "resend the signal" which just reboots your modem, and if you're really lucky sending out a highschool dropout to your house just for him to plug his handheld line tester in and verify that the signal strength is ok. You could show them the WinMTR traceroute and they'd just stare at it like "huh? whats that?"
Soooo... does anybody know how you actually get Tier 3 level support from Comcast? How to actually get a network engineer to take a look at that node in your city block and say "hmm, you know what this thing is totally overloaded! We need to spend a million bucks and upgrade this baby!" Or is it basically until droves of customers start canceling for unusable service, comcast will never really lift a finger if it requires this much effort.
My lease is ending and I am seriously considering relocating across fucking town just to put myself on a different routing path so I can use the fucking internet again.
