How to get another 100 MHz?
JJU357
Ok I'm @ stock voltage withthe stock HSF on my a64 3200+ @2.5 right now. THis is with the HTT at 3 and the FSB at 250 with kingston hyperx pc4000 ram...its completely stable. I was interested in knowing if i could use the divider and possibly get it to 2.6 while running the ram at 250 or at 200...I don't really understand the math part of the divider would someone care to enlighten me?
First of all, I'd be pretty damn pleased with 2500Mhz at stock voltage with the stock HSF, if you are truely acheiving that.
Second, if your chip is actually capable of more than 2500Mhz, than a slight .05 or .10 bump of the vcore and vdimm would achieve that without having to use a memory divider. You may, or may not, also have to slack up on the memory timings of your RAM very slightly to push it above 250, but I think your ram should handle 260 at stock timings.
You want to avoid using the memory divider if you can because 1:1 always gives you the best overall performance. The fact is that another 100Mhz of cpu clock speed may not make up for the 30-40Mhz decrease in memory clock speed of your RAM and the performance hit you would take by running your bus asynchronously.
I say give it a try. Try raising your voltage, or using a divider and tight timings, or going 1:1 with loose timings. Bench it all, take screenshots, and post back with what works best. :)
my 3000+ topped out at 2609mhz, thats a 290mhz HTT, memory is running at 192mhz (geil blue shield). I have a XP-90 cooling it, and it never gets over 90F under a load, even at 1.55 volts. i tried for 300mhz HTT (2700mhz cpu, 200mhz ddr) but it just won't happen, and i'm to chickenshit to try the voltage over 1.6. good luck though, i hope you get an even better overclock. I used the epox EP-9NDA3J motherboard, what kind of motherboard did you use?
People need to stop posting these redicious O/Cs with there Winchesters. As for the question. Bump up the voltage a bit on the cpu and mem, watch temps, Keep them under 55C full load and 60C for Seriously streesed temps like Prime95 and folding. Check for stabilty using one of these two, But I prefer folding. I am guessing you are close to your limit on stock cooling. If you were to upgrade to better aftermarket cooling IE Hyper 6, or XP-90 I am betting you can see a 100-200MHZ jump.
well i decided to push a little more...i may try for more this weekend but currently I'm running my 3200+ winchester @ 2.55 GHz with a 255 HTT and a 3x HTT multi. This is on 1.41 V and the stock HSF you can take a look at the proof below. Btw for those that were wondering this was on a MSI K8N Neo2 Plat with Kingston HyperX PC400 Ram.
