Sgt_Strider
- Oct 29, 2003
I just installed a new SATA drive to act as a data drive inside the computer. The problem is that I don't see any option to format the drive. That option is greyed out. Instead, the only option that I see the minute the drive was installed and Vista was installing the driver for it, was whether to use MBR or GTUIP for the partition volume. I picked MBR and then I still don't see the availability of the format option. The next step was to pick to pick "new simple volume", select NTFS as the file system and use default for the allocation unit size. I also checked "perform a quick format" and that made the format a lot faster. Next thing you know it seems like the hard drive was ready and that I can copy files into it. Did I do things properly? Why wasn't the format option available in the first place? Did you guys used MBR partitioning? What happens if I didn't check "perform a quick format"? What are the consequences? I would appreciate if all of my questions are answered. Thanks!
