How to flash BIOS?
MADWAD
So i have to update my Bios. No problems except i have to update them first using "AFlash". These are the directions below but being a noob i'm having trouble trying to figure them out.
AFLASH.EXE (unzipped) can only be executed in DOS mode and not from MS-DOS Prompt in Windows O/S. As a result, no matter if you wish to backup or update the BIOS content, you must create a new boot disk. Please copy AFLASH.EXE into the disk which you wish to boot the system. In addition, in the BIOS device boot sequence, you must set boot from "Floppy Drive" as the first device in the order of boot sequence.
Use Update using Aflash BIOS Update Procedure
1. ASUS Online Update (Download from ASUS WWW ` FTP) for latest version BIOS and save it on a floppy disk.
2. Use the floppy disk as described in above to boot.
3. In A:\ DOS mode, please unzip AFLASH.EXE (unzipped).
4. In MAIN MENU, please choose Update BIOS Main Block From File. Please refer to [2. Update BIOS Including Boot Block and ESCD] .
5. After the procedure has complete, remove the disk from the floppy drive and shutdown the power.
6. Reboot, hold down key and enter BIOS menu. You must choose "LOAD SETUP DEFAULTS" to activate the new BIOS, then reconfig other items in the BIOS menu.
So i have to download the aflash file to a floppy disk (but how do i make it a boot disk?" And how do i set boot to "floppy drive"? Really appriecate some advice concerning this. Thanks
To create a boot disk:
-go to my computer
-Rt. click on A:
-Choose Format
-Check off "Create an MSDOS startup disk
-When process is complete - copy over AWFLASH.exe to disk
-Also copy the new bios file to the disk
Done
To change boot order:
-Go in to the bios
-Go to boot options
-Move floppy A: to the first boot area
Done
ok made the boot disk no problems but how in the hell do i unzip aflash in dos mode?
The instruction for updating your bios on the ASUS website frigging suck!!!!
I've been trying to update my bios for the past three days!!!!!
Those instructions have been translated from German. You have to unzip Aflash in Windows, and copy the Aflash.exe to your boot disk, along with the new BIOS file.
Take a look here if you have any more questions.
MOTHER OF GOD!!!!!!!!!!! This is just too frigging stupid!!!! So i figured out everything except when i go to flash to the newest bios (i got off the ASUS website) this comes up
WARNING!!!
The file is not ASUS's BIOS
The Bios Model doesn't match
with the one currently used
continue?
Now, before you even ask "YES" the bios i downloaded are for my motherboard (ASUS P4PE mobo). I checked on the box my mobo came in and on the actual mobo. This is such a pain.......please help.
Repo, there the same ones i downloaded. what now? I certainly can't get an answer out of ASUS, their customer service is complete crap!!
Hey repo, thanks for the help bud but i fried my mobo by flashing the wrong bios (p4pe1007). Well this sucks and tommorow i have to buy a new mobo (need to use my computer right away(middle of exams)) Thanks for the suggestions anyways.....LOL :eek: :mad: :confused:
That sucks big time man. There isn't much that can be done when a motherboard flash goes wrong. Hope everything works out for you.
