tehandydumke
- Feb 6, 2004
Alright right now I'm at like 255FSB with a divider of 5:4, stock timings 2.5-3-3-6 and its being unstable. I was wondering how I go about finding the right fsb, memory timings and divider. I'm going to set my divider to 3:2 tomorrow and raise my voltage to 1.6. I can't right now because I'm at my dads house. My ram voltage is 2.75 which is max for my motherboard. I was just wondering how you guys go about finding the right fsb. What I was thinking is to find the max OC you can with zero errors and then underclock it alittle from there. Then try to tighten your timings as much as possible and lower the voltage as much as possible.
Does this sound correct? What would you do differently? Thanks !
