Photocat73
- Jun 21, 2006
I have some suspicious behavior on my home system, but have thrown all the antivirus, adware, spyware, reg scrub, online scans, port & combination scanners, and network monitoring apps that I know of at my system, to no avail...The random power down of the PC is especially bothersome! All of my antivirus, scan programs, and firewall are updated and report no problems. And yes, I only have one of each installed at a time to ensure compatibility
Can anyone suggest a utility that would protect itself but still listen for hidden problems? I'm running out of ideas and my networking instructor at school suggested I ask you guys/gals. The only catch is it has to be freeware or pretty cheap, as I am still a broke student. Thanks!!!
Programs used:
AVG
Avast Pro
Nessus
Ad-aware SE
Spybot S&D
Spyware Blaster
Hijack This
Advanced Port Scanner
Wot Web Scanner
Trend Micro Housecall
RegScrubXP
C-Cleaner
SANDRA
Cacti
ZoneAlarm Firewall
Programs used:
AVG
Avast Pro
Nessus
Ad-aware SE
Spybot S&D
Spyware Blaster
Hijack This
Wot Web Scanner
RegScrubXP
C-Cleaner
SANDRA
Cacti
ZoneAlarm Firewall
