How to enable side band addressing?
TommyW
I have epox 8rda3i mobo... based on nforce2 ultra400
i dont no how to enable thw side band addressing...
i cant find it in the bios menu :(
help help help :(
You really don't want sideband addressing, unless you know why you want it.
EDIT: What I wrote makes no sense.
You really don't want it. It's only advantage is that it cuts down on EMI. Things tend to work less well when SBA is enabled.
If EMI is that much of an issue...put your case covers back on, or build a weak faraday cage.
The second part doesn't make much sense either :D
Sideband adressing is a frail lil performance feature of the geforce3/4 series that produced very lil performance boost but plenty of instability for most. It can be activated in some bios's but usually via 3rd party oc'ing software. Don't bother with it since i highly doubt it'll net more than 50/100 3dmark2001 points (worthless).
Then again the OP question doesn't make much sense since he posted it in Mainboard forum :D
Then again, it makes even less sense that he's trying to activate it on a 9800. heehee
