How to enable cctl for ph3400u inside the raid?
osk666
Hello.My system is win8.1.
My raid controller model is 9260cv. Hard drive model is ph3400u. Before I bought the
drives, I had checked that the drive support cctl but it is disabled in default.
I first insert the drive into the raid controller. Then I try to ran the smartctrl.
However, I cannot find the drives behind the raid controller.
Then I run the following command:
smartctl -d csmi -r ioctl,2 --scan
\\.\Scsi0:: successfully opened
IOCTL_SCSI_MINIPORT(CC_CSMI_1) failed, Error=1117
\\.\Scsi1:: successfully opened
\\.\Scsi2:: successfully opened
\\.\Scsi3:: successfully opened
\\.\Scsi4:: successfully opened
So, it showed that the driver does not support csmi?
Then I cannot use the smartctrl to enable cctl for the drives?
Then I try to directly connect the drive to my motherboard and the the smartctrl.
smartctl -l scterc,80,80 /dev/sdf
After running the above command, I suscessfully enable the cctl. However, after the power cycle, it becomes disabled again.
Is there any other tool that I can enable the cctl for the raid?
Is it the only way for me is to return the drives?
Thank you very much.
