Hello all.
I was wondering what I should do when I need to empty the water out of my loop. I bought two cutoff valves but don't know where to put them. Suggestions appreciated! Thanks..
PS . I would like to empty out the water with the system off since the pump can't run dry... so I'm thinking somewhere near the bottom, but, should I put a cut off valve down at the bottom and then use a disconnect to it to fill a bucket or something? I was also thinking of putting the second cut off valve on the top in the inlet of the res so it won't spill back.
EDITED - please look at picture in my next reply
