How to dustproof my PC ? Materials...
baronpork
As of late i'm getting loads of dust in my case, mostly due to building work next door. Need to dust proof my PC.
Case is Antec900 with all fans on low, need custom cut piece of foam for two front fans, which is apprx 300x160mm, and side panel for 120mm fan (no fan, cant fit it due to huge cpu tower cooler). I'll make the frame myself, but where do i get non-precut piece of filter foam for this? Quarter of a square metre would be good (500x500mm)...
I only find small pieces suitable for individual fans. Cant be bothered disassembling whole machine just to get to the front fans.
Also, how are they rated in terms of airflow ? What sort of foam (or other materials) should i be looking for ?
Any advice on this is welcome.
Thanks...
