I have one computer I started using just for recording/playing video on the tv. Yesterday it picked up a virus (System Security) when I was transferring files from it via my LAN. I downloaded a Malaware Program to delete the virus but the program won't execute and install-- neither will any other program.
I think I'm stuck with having to reinstall WinXP using the rescue disk (Hope it works). When I am back and running I would like to completely prevent the possibility of virus from the internet. I went to My Network Places and disable the Internet Connection but that disabled all my computers on the LAN!!! Seems to me it should only disconnect THAT computer, but no, it took down the whole system.
I assume that removing IE7 and Firefox from the puter will help but not be 100? I'm going to remove them anyway assuming some/most viruses use the browser to get into the system.
Any other ideas/cautions? Thanks.
Progress===I found the following:
: How to disable Internet connection without disabling the LAN/network?
1. From the Start menu, select either Control Panel, or Settings and then Control Panel.
2. Double-click Network Connections, and then Local Area Connection. In the Local Area Connection Status dialog box that appears, click Properties.
3. Click to highlight Internet Protocol [TCP/IP] , and then click the Properties button.
4. Select the radio button for Use the following IP Address, and enter the IP address of your computer.
5. Enter the correct code for the "Subnet Mask" field.
6. Enter the correct information for the "Default Gateway" field, in this case that would be deleting all the information.
7. Enter the correct information in the "Preferred DNS Server" field and the "Alternate DNS Server" field, in this case that would be deleting all the information. .
8. "OK" your way out of the properties.
But I get hung up at step 4 as the three computers on my LAN all have the same IP Address. Seems once again my entire LAN might go down AND once again, seems something isn't right in my house if the unique IP for each COMPUTER is in fact shared by the three computers on my LAN. Seems like some menu pull down item is stuck in the cybersphere? I'm also damn scared why/when my other two computers will pick up this same virus==it is rather close afterall. Each computer is running different firewalls and AV programs and anti scrip running software.
