Feb 22, 2005 #1 M MATTRESS Gawd Joined Sep 26, 2003 Messages 992 w00p found it duh ... under control panel .. sounds ... windows explorer ... start navigation <none>
Feb 22, 2005 #2 T totmachen Limp Gawd Joined Jun 18, 2003 Messages 177 In the control pannel, go into sounds and audio devices, then click the sounds tab. Scroll down to the windows explorer section and find start navigation. Change that from the click noise to none, ok out and you should be set.
Feb 22, 2005 #4 O OldMX 2[H]4U Joined Mar 17, 2002 Messages 3,532 Control Panel / Sound and Audio Devices / Sounds Tab / select "Windows Explorer Start Navigation" and disable the associated sound go0d Luck OldmX
Feb 22, 2005 #5 M mosin [H]ardForum Junkie Joined Sep 30, 2001 Messages 6,558 The best way to disble it is to passcode IE, and start using Firefox.
