Coldblackice
- Aug 14, 2010
Is there a way to disable the utterly annoying mouse middle-click autoscroll function? It's activated by pressing the middle mouse button, usually in web browsers (but also other programs). When pressed, it changes the mouse cursor to an omnidirectional free-flow cursor, and wherever the pointer moves, the window smoothly scrolls in that direction.
This isn't the commonly referred to "smooth scrolling" feature, which Googling shows frequently suggested as the solution which it's not.
tl;dr
I have a G502 with a now busted middle button. I can still use the middle button, but it doesn't have a click anymore, essentially stuck in the down position just barely above the click threshold. I slammed the mouse down out of frustration the other day -- uncharacteristic of me, it was the game's fault -- I assume I either broke or dislodged some lever or spring tied to the wheel.
Free-spinning still works fine, but in non-free/click scroll mode, each ridged scroll activates the middle mouse button as if I'm holding it down, similar to a keyboard key when something gets stuck below it.
I assume it's a broken part vs. something dislodged, but if anyone familiar with the G502 knows its inner layout and the likelihood of it being a broke part vs. dislodged, I will disassemble the mouse to fix it. Otherwise I assume something broke and chalk it up to a foolish loss on my part.
tl;dr
