How to disable 7970 power saving feature?
Melon
I'd like for my 7970 to not power down when my PC is idle, due to mining.
How would I go about disabling the power saving feature?
Using MSI Afterburner.. there latest beta 12 has a setting that will force consistant voltages.. i bet that will be your answer other then editing the bios which i'm not sure if there is a bios editor that will currently work with the 7970.
Gotcha, thanks for the reply.
