How to decrease heat output of PC?
sitheris
Rig specs are below.
I'm having some heat issues with my rig, it's making my room really hot. Is there anything I can do to cool it down? I'm just using the stock case fans and everything, but i have an arctic silencer on my video card.
I am replacing 2 of my hard drives with a single 400gb drive so that may reduce a little bit of the heat.
Is there anything else I can do? Also, it's still not really warm enough to turn on the AC in the house yet so that's out of the question
Underclock everything (lower the voltages), and use AMD Cool'n'Quiet.
You could also get a single room A/C instead of using the entire central A/C.
Blowhole
Remove components, make all fan openings into 120mm, neaten wires to maximize air flow.
If the temperatures drop by more than one or two degrees with the side panel off, it is poor case ventilation that is the culprit. If temperatures do not drop, research some high performance air coolers.
The fact that the PC is in the room means a better flowing case will actually heat the room better.....:eek: Using parts that consume less power and generate less heat is really the only answer.
Energy can neither be created or destroyed. Adding more fans or better cooling won't reduce the amount of heat being produced, only remove it from the case itself. The room will still be the same temp.
The only real things you can do is to underclock, use cool & quiet, things of that nature.
Otherwise, you'll either have to cool the room better, or vent the exhaust from the PC out of the room.
