I built a system a couple of months ago and it has been rather unstable (getting worse). The components are:
nf4 ultra-d
fsp 600w-gln (over kill)
x1800xt 512mb
2 1gb G.skill D500 F1-4000USU2-2GBHZ
san diego 3700+
1 optical eide
1 74gb raptor
I am not overclocking - memory is using auto defaults (but look correct from atool/cpuz) and proc is at 2.2 ghz. Clearly something is bad (memory, cpu, psu, mother board).
Any suggestions of how to find/figure out what is busted? I do not have a probe so i cannot measure voltage directly but i am running mbm5 which seems to indicate reasonable values. Again according to mbm 5 max cpu temp is 45 with mean around 42. max video temp is 81 (which is normal for 1800xt) north bridge is 50c.
I just want to figure out which component is bad and fix it !
Thanks,
You
nf4 ultra-d
x1800xt 512mb
san diego 3700+
1 optical eide
1 74gb raptor
Thanks,
You
