I decided to create a 5 disk RAID 0 array in Linux. I'm running Ubuntu 6.10
Here is the procedure I used. I think it is the correct way, but I'm having problems getting the array to mount.
(Created a primary partition with the full size of the HD, then used "t" and "83" for partition type)
***denotes operation output
I used /dev/.static/dev/md0 because it was posted in another HowTo that I used some info from. Why not just use /dev/md0? How does this affect the array down the road? id the /dev/.static needed?
Used to stop the array
Add the following lines:
DEVICE /dev/hda1 /dev/hde1 /dev/hdf1 /dev/hdg1 /dev/hdh1
ARRAY /dev/md0 devices=/dev/hda1,/dev/hde1,/dev/hdf1,/dev/hdg1,/dev/hdh1
This is where it gets strange...
WHY won't this start, considering that I made the /etc/mdadm.conf file?
This is the step by step procedure that I used. How do I configure this in the fstab? Is it different for RAID arrays? Do I need to include the UUID : 54623f8b:b3b44af:45dca40a:d0833744 in the fstab?
Also, when i created the /etc/mdadm.conf , do I use /dev/.static/dev/md0 or /dev/md0?
Finally what do I use to create a file system?
sudo mke2fs -j /dev/md0 or
sudo mke2fs -j /dev/.static/dev/md0 ?
I created /raid directory for my array mounting point, then adding this to my fstab
I then tried creating the FS with this:
What do I do to correct the /dev/md0 not having a valid partition table?
Code:
sudo apt-get install mdadm
sudo fdisk /dev/hda1
/dev/hde1
/dev/hdf1
/dev/hdg1
/dev/hdh1
Code:
[COLOR="Blue"]cd /dev/
sudo MAKEDEV md
sudo modprobe md
sudo mdadm --create --verbose [COLOR="Red"]/dev/.static/dev/md0[/COLOR] --level=0 --raid-devices=5 /dev/hda1 /dev/hde1 /dev/hdf1 /dev/hdg1 /dev/hdh1[/COLOR] You can change the --level=0 to the appropriate level for the array you are configuring
***mdadm: layout defaults to left-symmetric
***mdadm: chunk size defaults to 64K
***mdadm: /dev/hde1 appears to be part of a raid array:
*** level=raid5 devices=5 ctime=Wed Feb 21 03:27:41 2007
***mdadm: /dev/hdf1 appears to be part of a raid array:
***mdadm: /dev/hdg1 appears to be part of a raid array:
***mdadm: /dev/hdh1 appears to be part of a raid array:
***mdadm: size set to 156288256K
***Continue creating array? y
***mdadm: array /dev/.static/dev/md0 started.
Code:
[COLOR="Blue"]cat /proc/mdstat[/COLOR]
***Personalities : [raid5] [raid4] [raid0]
***md0 : active raid0 hda1[0] hdh1[4] hdg1[3] hdf1[2] hde1[1]
*** 781443648 blocks 64k chunks
Code:
sudo mdadm -S /dev/md0
Code:
sudo gedit /etc/mdadm.conf
Code:
[COLOR="Blue"]sudo mdadm --detail --scan[/COLOR]
***ARRAY /dev/md0 level=raid0 num-devices=5 UID=54623f8b:b3b44af:45dca40a:d0833744
Code:
[COLOR="Blue"]sudo mdadm -As /dev/md0[/COLOR]
***mdadm: /dev/md0 not identified in config file.
Code:
[COLOR="Blue"]sudo mdadm -A /dev/md0 /dev/hda1 /dev/hde1 /dev/hdf1 /dev/hdg1 /dev/hdh1[/COLOR]
***mdadm: /dev/md0 has been started with 5 drives.
Code:
[COLOR="Blue"]sudo mdadm -E /dev/hda1[/COLOR]
/dev/hda1:
Magic : a92b4efc
Version : 00.90.00
Creation Time : Sun Feb 25 13:54:18 2007
Raid Level : raid0
Device Size : 0
Raid Devices : 5
Total Devices : 5
Preferred Minor : 0
Update Time : Sun Feb 25 13:54:18 2007
State : active
Active Devices : 5
Working Devices : 5
Failed Devices : 0
Spare Devices : 0
Checksum : 436417f3 - correct
Events : 0.1
Chunk Size : 64K
Number Major Minor RaidDevice State
this 0 3 1 0 active sync /dev/hda1
0 0 3 1 0 active sync /dev/hda1
1 1 33 1 1 active sync /dev/hde1
2 2 33 65 2 active sync /dev/hdf1
3 3 34 1 3 active sync /dev/hdg1
4 4 34 65 4 active sync /dev/hdh1
Code:
# /dev/.static/dev/md0 UUID=54623f8b:b3b44af:45dca40a:d0833744 /raid ext3 defaults 0 0
Code:
[COLOR="Blue"] sudo mke2fs -j /dev/.static/dev/md0[/COLOR]
***mke2fs 1.39 (29-May-2006)
***Filesystem label=
***OS type: Linux
***Block size=4096 (log=2)
***Fragment size=4096 (log=2)
***97681408 inodes, 195360912 blocks
***9768045 blocks (5.00%) reserved for the super user
***First data block=0
***Maximum filesystem blocks=197132288
***5962 block groups
***32768 blocks per group, 32768 fragments per group
***16384 inodes per group
***Superblock backups stored on blocks:
*** 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
*** 4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
*** 102400000
***Writing inode tables: done
***Creating journal (32768 blocks): done
***Writing superblocks and filesystem accounting information: done
***This filesystem will be automatically checked every 24 mounts or
***180 days, whichever comes first. Use tune2fs -c or -i to override.
[COLOR="Blue"] sudo fdisk -l[/COLOR]
***Disk /dev/hda: 160.0 GB, 160041885696 bytes
***137 heads, 8 sectors/track, 285202 cylinders
***Units = cylinders of 1096 * 512 = 561152 bytes
*** Device Boot Start End Blocks Id System
***/dev/hda1 1 285202 156290692 83 Linux
***Disk /dev/sda: 37.0 GB, 37019566080 bytes
***255 heads, 63 sectors/track, 4500 cylinders
***Units = cylinders of 16065 * 512 = 8225280 bytes
***/dev/sda1 * 1 4314 34652173+ 83 Linux
***/dev/sda2 4315 4500 1494045 5 Extended
***/dev/sda5 4315 4500 1494013+ 82 Linux swap / Solaris
***Disk /dev/sdb: 74.3 GB, 74355769344 bytes
***255 heads, 63 sectors/track, 9039 cylinders
***/dev/sdb1 1 1200 9638968+ 83 Linux
***/dev/sdb3 1201 3000 14458500 83 Linux
***/dev/sdb4 3001 9039 48508267+ 83 Linux
***Disk /dev/hde: 160.0 GB, 160041885696 bytes
***255 heads, 63 sectors/track, 19457 cylinders
***/dev/hde1 1 19457 156288321 83 Linux
***Disk /dev/hdf: 160.0 GB, 160041885696 bytes
***/dev/hdf1 1 19457 156288321 83 Linux
***Disk /dev/hdg: 160.0 GB, 160041885696 bytes
***/dev/hdg1 1 19457 156288321 83 Linux
***Disk /dev/hdh: 160.0 GB, 160041885696 bytes
***/dev/hdh1 1 19457 156288321 83 Linux
[COLOR="Red"]***Disk /dev/md0: 800.1 GB, 800198295552 bytes
***2 heads, 4 sectors/track, 195360912 cylinders
***Units = cylinders of 8 * 512 = 4096 bytes
***Disk /dev/md0 doesn't contain a valid partition table[/COLOR]
[COLOR="Blue"] sudo mount /dev/md0[/COLOR]
***mount: can't find /dev/md0 in /etc/fstab or /etc/mtab
[COLOR="Blue"] sudo mount /dev/.static/dev/md0[/COLOR]
***mount: can't find /dev/.static/dev/md0 in /etc/fstab or /etc/mtab
[COLOR="Blue"]sudo gedit /etc/mtab[/COLOR]
***(((I added /dev/md0 /raid ext3 rw 0))))
[COLOR="Blue"]sudo mount /dev/md0[/COLOR]
***Cannot create link /etc/mtab~
***Perhaps there is a stale lock file?
