How to correctly update chipsets
jnick
Hey guys.
I have the MSI K8N Neo2 Platinum. The way I updated my nForce Chipset was installing the one's on the CD, then installing the Update from MSI on top of them.
Should I run Driver Cleaner to clean out the nForce drivers, then reinstall the updated one's?
Thanks guys.
Jnick
jnick said:
Hey guys.
Thanks guys.
Jnick
*enter nitpick mode just to tease you* So, you're saying you updated your chipset on your motherboard from an NForce 3 to a NForce4? COOL! I'm updating mine to an NForce 5!! :D :p *end nitpick mode*
Yes, I know you meant the drivers. ;)
Anyway, what I'd do is download the latest chipset drivers from NVidia itself, unless you know the ones on your motherboard's CD-ROM and/or the ones from MSI are just as new. And yes, uninstalling the chipset drivers first before installing the new ones are good, running driver cleaner might be wise too.
Remember to at least remove your video drivers too before reinstalling the new chipset drivers. Don't put back on the video drivers until you have the chipset drivers back on first.
Sorry if you knew that, it is sometimes surprising how many don't.
Thanks for the instructions man.
Yeah, I just figured out it's Chipset DRIVERS, lol. Anytime I'd search it, nothing came up!
Take care.
Jnick
