How to copy VHS to the PC?
DarkSamurai2003
How do I copy VHS Tapes to the PC? What equipment will I need, or are there any easy to follow tutorials online?
You will need a video input device for your computer (IE - Pinnacle Studio, Dazzle, something to that effect that has VIVO capabilities) and software that will recognize the camera and the input device.
Any video capture device will do. If you want professional quality editing, use a Premiere Pro certified capture device. If you want a budget, decent quality one, the cheap PCI based solutions are significantly better than the cheap USB external solutions. Two of the cheap products that people have had good luck with, including myself, are made by Avermedia and Hauppauge. The low end models run $50-$80 and have pretty good capture quality but poor editing and converting software because the pricepoint is too low to include the really good stuff. You can always "borrow" professional quality software to use after the capturing is done, or if you simply want them archived with good compression and quality, Divx converter 6.0 is really cheap and has excellent compression with almost no advanced customizations.
If your looking at a new videocard anytime soon, an ATI All-In-Wonder card would suit your needs as well.
