how to cool this stuff ??
nightwalker
i have a danger den waterbox plus and it only has space at the bottom for a dual rad which i have... it works fine with my cpu but im getting a 8800 soon and ive heard they put off ALOT of heat so im guessing my black ice pro 2 just isnt gonna cut it :p
any ideas ?? the only other fan holes is the 2 x 80mm ones above the cpu but then my case would have no clean airflow through it lol
How far are you overclocking?
I ran a heavily OC'd GTS and a C2D on a BIPXflow 240... Temps were acceptable.
i wouldnt push my e6300 past 2.8.... and not even overclock my 8800.....
that might be ok then... can someone recemmend me a dual rad that would be suitable then ? and least costly lol
Well, the MCR radiator would net you about 10%... not enough to justify the cost.
And, as I said, GTS and E6300 were heavily overclocked on a radiator that's WORSE than yours.
Just get 4 yate loon fans and run them push/pull.
ive got 2 yate loons pulling the air out... would it really make much difference if i added 2 other fans to push aswell ?
