How to convert from AVI to DVD (2 AVI files)
MaXimus
Hi guys, I am using AVI2DVD to convert some of my AVIs into DVD into DVD format then burn them.
Now when I copy one movies it's all good, and fits perfectly on one DVD.
But what if I want to convert 2 AVIs (2 part movie) into ONE DVD? how do I go about doing that?
DVD Shrink is your best bet to shrink it down but you will need to d/l vso dixv to dvd first to convert them to vob files and you cantake both files and put the into one folder on your comp then use vso dixtodvd to to convert them both at the same time I just tested this approach and it should work best of all both programs are (insert loud announcer voice) FREEBIE (turn offf loud announcer voice).
DVD Shrink
LINK
VSO DivxToDVD
LINK2
If you haven't already, I'd suggest checking out the guides at doom9.org--you'll find just about everything you could ever want there, and the site is updated pretty regularly.
