Hello all. I'm looking for a solution to my current predicament. I would like to control all my fans based on water temperature. Is there a hardware solution for this that doesn't cost an arm and a leg? I want it to ramp up the fan when the suppurate of the water increases. Normally, I would just have the motherboard control the fan via CPU temp, but the problem is that it cannot seem to do this, even when only one RPM sensor is hooked up. What will work? I'm looking at a max of 25A total current.
