what can i use to control the speed of my fans without having to buy a fan controller? cant i just hook the fans into the fan plugs on the motherboard and control them from a program?
I know you want to do it via software, but it depends if you MB support adjustable V+ to the fan or if the fans are running off the 12+/5+ Molex or from the cpu/case 3pin fan. You can also get a potentiometer (at Radio Shack)
You can splice the (+) and put the pot there. You can wire the pot to stick out of the rear of the case.
I do not know what exact Ohm Pot you'll need, but it is doable. You'll be able to control from OFF to FULL with this.
I also second the potentiometer for speed control. Thats how I get 100 CFM instead of 235 CFM outa my Rotron160mm fan! Otherwise it sounds like a jet plane! don't turn the dial to low or the fan will not start up agian. you can run some fans at 5V but they will not turn from a standstill at 6V.
Try a 1500 ohm pot.
