Its pretty simple. The first time you launch it, it will open up a menu session that allows you to configure a bunch of different things. Most of it is self explanatory and most of it can be left untouched.
The second step is for you to run the client and wait until it flushes work units back to the distributed.net proxy network. Anywhere from 0 to 24 hours after your client first flushes some work units back to us, our stats server will detect that you are a new participant and start publishing stats about your work as well as your ranking on its web site.
You should then lookup your personal statistics on the stats server in order to view your personal stats page. If you are participating in the RC5-72 contest, for example, click on the 'RC5-72' link from the http://stats.distributed.net/ page. You will be directed to the http://stats.distributed.net/projects.php?project_id=8 page at the top of which you can enter your email address in the search field of the 'Participant Stats' column.
If you enter your full email address or if the search based on your query only returns one result, you will be directly directed to your personal stats page. If you entered a more generic keyword in the participant stats query form, you will be directed to a page listing the first 50 results that match your query. From there, you can click on a participant's name and you will be directed to the corresponding personal stats page.
Your personal stats page for one of our projects contains statistics related to your contribution to a that particular project. If you participate in multiple distributed.net projects, you will have as many project-specific personal stats pages as number of projects you are contributing to. The stats web site is broken down into various sections for each of our projects. Each section can be accessed from the links in the table listing our different projects on the http://stats.distributed.net/ page.
Finally, you will need to request that your stats password be sent to you by email to the address that you specified in your email client configuration, which is also the one under which you appear in the stats server. To do this, you must be on your (or one of your) personal stats page(s) and click on the link at the very bottom of that page that reads: "I cannot remember my password. Please email [insert your email address here]'s password.". Once you click on that link, you should receive an email with your stats password shortly thereafter.
Note: Your stats password will not be automatically mailed to when you first flush work units back to our servers. You must necessarily follow the procedure described in the previous paragraph to request your password.
Once you have a stats password, you will be able to click the "join this team" page from the HardOCP stats page.
