leeleatherwood
- Sep 6, 2011
Ive got this 2500k at 5.0ghz stable, 1.5 volts, watercooled. Motherboard is Asus Maximus Gene-V
I have enabled speedstep in the motherboard and it does indeed decrease the cpu speed when idle to 1600mhz but the voltage does not decrease with it. I have also enabled the EPU power saving thing in the bios but that doesn't change the CPU speed either.
I am new to Intel systems, specifically the Core-i series, so I need some advice.
