How to config autorun.bat
Wazabi
My computer wont install windows,i've tried everything and i mean EVERYTHING.
My last option is to update my mobo drivers,i'm trying to make a bootable cd but I need to configure the autorun.bat to run setup.exe. What commands do I need to put into the autorun.bat to accomplish this? Any help is appreciated.
Since it's been a while since the last time I messed around with a batch file I'm going to assume it's still written in a variation of BASIC? Anyway, all you would have to do is type the path of your CD-ROM and the filename where you want it to run...I.e. "D:\Setup.exe"
But, before you start screwing around with batch files, you should make sure you really have to...You should list what is going on and what all you've tried so far.
I've tried EVERYTHING
This has me stumped man.
I've swapped out every single part..ram,power supply,cd rom,hard drive,winxp cd,vid card...it just refuses to install windows...it will load up the drivers then freezes at the setup is loading windows. I've tested all the parts in other computers and they all seem to work fine.
Now what I did was I pulled the CPU out of my sisters old e-machine and built a new comp around it(excluding hard drives) The e-machine did the same exact thing when I tried to install windows as well. So I know its not the new mobo or ram. The only thing left for me to do is buy another CPU..But I don't see how it can be the cpu fritzing out cause it always freezes at the same exact spot upon installation..I think if the chip was bad it would be more random right?
Well thanks for any help !
It would make sense if it where random, but it could be that at that certain part of the installation it is attempting to use more of the cpu's power and that could be the problem. Also, have you checked that all the pins are nice and straight? If it where doing the same thing in the other machine, I'd suspect the cpu as well. I had kinda the same troubles with an HP machine I was fixing for a friend recently. Everything would be just fine until you got about 3/4 the way through the install and it would stall at 33minutes. I removed the power cord from the back (not very smart, but...) then restarted the process 3 times. It finally took on the last time, so you might wanna just keep trying that? If not, I'd really go for a new cpu.
