How to Combine WAN and LAN?
Dr_Fuzz
Heres the setup,i have 3 desktop PC's and 1 notebook. 2 of the desktops are connected by wire.The notebook and remaining desktop uses wireless connection.All 4 systems are connect to a DI-624 router.They all have internet access but my problem is File and Printer sharing.Basically my wired computers do not see the wireless computers. How do i fix it or how do i set it up to where i can have all of my computers on 1 network ?
thanks in advance.
Bump.
Or is it impossible for wireless and wired systems to be in one network to share files and printer?
Yes,heres the layout
my.php
[/URL][/IMG]
Fuzz,
I do not have your particular router but it should be transparent between the wireless and wired portions of it unless you have set some security/firewall option to segregate the two. Are you running any type of software firewall on the systems themselves?
Yes,each PC has ZoneAlarm installed but i have tried it with the firewall disabled.
That is wierd...
Double check the workgroups and make sure the file sharing are enabled
and then goto my network places and try to add a location,
See if it will see it there
What i had to do with my Wired/wireless
after it was all setup, just went to My Network Places
Browse for the location than Entire Network, Microsoft Network
Pc's should be in there, just add locations one by one
Hope it works for ya
If you want to have all of the computer to be on the same network then they're subnet masks have to be the same...
What are each computer's ip address, subnet masks and installed protocols?
If you dont want them to be seperated like they are now, then you need to correctly setup a
routing table with the subnet masks of each network to see eachother.
