How to clean your LCD?
Mastrhiggins
What is the best method to clean your LCD without harming any coating or the screen for that matter??
I use a damp cloth.
Not very damp...just barely...
No chemicals, no soap.
EDIT: I figured I'd flip through my manual just to see what they suggest.
* To clean your antistatic screen, lightly dampen a soft, clean cloth with water. If possible, use a special screen-cleaning tissue or solution suitable for the antistatic coating.
Do not use benzene, thinner, ammonia, abrasive cleaners, or compressed air.
* Use a lightly-dampened, warm cloth to clean the plastics. Avoid using detergent of any kind as some detergents leave a milky film on the plastics.
* If you notice a white powder when you unpack your monitor, wipe it off with a cloth. This white powder occurs during the shipping of the monitor.
* Handle your monitor with care as darker-colored plastics may scratch and show white scuff marks more than lighter-colored monitor.
civictyper16 said:
I guess people dont see the search button. :rolleyes: :rolleyes:
Tell me...does it make you feel better inside when you point that out?
We are not as smart as you I guess...get over yourself.
Most of the time it is not "smarts" that cause people to not use search, it is lazyness, and having to answer the same question every single week is annoying to regulars of not just [H] but any forum.
