How to clean a glossy LCD
Glow
Okay so everyone said use microfiber and bestbuy LCD kit before, saw it made lightscratches, I got this samsung rag thats smooth and soft just sposed to wet it and all it did was leave smudges. So how the heck do you clean these things?
I have a microfiber cloth I stole off of a friend who probably got it from wall mart, and I just dip it in some water, then wipe it off with 2-3 pass overs the screen, wait for it to dry then go over it again with the back of my hand and it wipes off all the smudges. only on a glossy screen though.
LCD cleaner solution, and a special microfiber glass cleaning cloth (parallel ridges). I use one cloth for application, and one to dry. I keep both in a ziploc for storage, since any oil or dirt on them ruins the cloth and leaves streaks.
yeah I dunno microfiber seems scratchy I dunno this is going to sound stupid but can u wash them is the washer?
I have a glossy monitor and what I did was use a microfiber cloth that I had and put solution on my monitor ( http://www.newegg.com/Product/Product.aspx?Item=N82E16882021002 ) and just wipe it and do the best I can and of course the smudges will be there still then I used that microfiber thing that came with the rosewill pack and it didn't really work but if I pressed a little harder and did circle motions and it got rid of them! After I was done my lcd looked like I just barely pulled it out of the packaging box for the first time! Seriously the cleanest I have ever seen it for a while.
I have a samsung 226bw and the plastic of this thing scratches easily, but I use i-cleaner (the stuff to clean ipods) and it's very good for removing the light scratches and leaves your monitor really shining.
Just make sure you get the right kind of laundry detergent. It will have a sticker "LCD SAFE"
Microfibre cloths will not scratch your screen. You should be able to find them easily in any store that sells car detailing equipment. I personally handwash my microfibres with liquid detergent + warm water. You can use the washing machine, BUT you CANNOT MIX THEM WITH COTTON fabrics. Once you do that, all the lint/loose cotten fibres will all get tangled up in the microfibre.
I remember picking up a pack of 20 cloths at Costco. I use them for everything now.
Well the microfiber that came with the LCD cleaner I got scratched my glossy macbook so I'm kinda parranoid
