How to Clean 7000AlCu....
Pyke
WITHOUT REMOVING IT?
Having two cats and an overly dusty house has lead to a really dirty Zalman HSF. I took a can of air to it, but the fins close to the MB are packed. Ideally I would like to do it without removing it.... ideas?
Also, what does everyone recommend for filters for intake fans?
Thanks!
p0intphreek said:
take off the fan??
then vacuum
You could do that, but it is easier to buy some compressed air and blasting the fins clean. If it doesn't remove all of the dust, cat dander, take an old toothbrush (preferrably dry and your room mates) and gently brush it upwards away from the fan. Then take the canned air again and blast away. Should be nice and clean in less than two minutes.
-E
Thanks!
Compressed air and blast away. Make sure your computer is off though.
after you get it cleaned might trying to put a filter on intake fans, helps with the 2 cats i have.
