You can hit the Delete key when you first turn on your PC to go into BIOS and see what temp your CPU is running at along with other temps. Whether or not you can read the video card temp will just depend on the video card. Usually only the expensive video cards have a thermal monitoring diode built onto them. I bought a 5900XT that even showed having temperature monitoring in the manual but it doesn't.
