how to change HD name
rob75
Hi all,
I need your suggestion about how to change HD names.
I've joust built a PC, and my motherboard has various IDE and SATA ports, where I have
connected:
HD1 (sata disk): SATA connector
HD2 (Ide disk): Ide connector number_1
cdrom_1: Ide connector number_2 (master)
cdrom_2: Ide connector number_2 (slave)
Everything works fine, and Windows XP shows the following:
HD1-- C:\
HD2-- F:\
Cdrom_1 -- D:\
Cdrom_2 -- E:\
Now, I'd like to change HD2 name from "F:\" to "D:\"
It seems to be a banal problem, but despite my trials (add/remove Jumpers, change Ide connectors, and so on...)
Windows always see the same Disk names.
Also disconnecting CDROM's, and attaching HD2 to their Ide connector,
XP always shows HD2="F:\"
Question: Is there any method to force HD2 to be "D:\" ?
Thanks for any suggestion
Roby
Use Disk Management to relabel them:
Start -> Run -> 'compmgmt.msc'
Go to Disk Management, right click on the partition/drive you want to change the drive letter of and select 'Change Drive letter and Paths'
Hmm, it looks like you're looking at the wrong places.
Try this:
1. Go to Run, type 'diskmgmt.msc' and press enter.
2. Now you see all your partitions.
3. Right click a partition, and you should see something like 'Change drive letters and paths' or something like that.
BTW, you can't assign a letter that is already being used. For example, if you want to swap D: and F:, you need to first assign one of them, say D:, to something else, say Z:. Then assign F: to D:, then Z: back to F:.
And DON'T do this to the system partition.
For renaming, how about a simple solution:
1. Open Windows Explorer
2. Right click on drive
3. Select rename.....................
How about a correct solution?
He wants to change the drive letter, not the label.
Well sorry I gave him additional information for renaming, as the solution is provided above. I didn't state my solution was for relabeling. :rolleyes:
Your suggestion works very well, problem is finally fixed!
THANKS A LOT!!
With the Best Regards
roby
THANKS A LOT!!
roby
Glad it worked out.
And welcome to [H], enjoy your stay.
Sorry, it seemed that your first line was sarcasm and mockery.
