how to change booy up sequence
bcham
i have 26" hdtv connected to my 8800gts.threw dvi to hdmi.my monitor is a 20" widescreen hpw2007 which only has a vga socket ,so when i boot up my pc it always boots the dvi first, bios comes on my hdtv then windows comes to my new monitor after boot up,can i change the way it boots so my monitor boots first.when i change the graphics driver i have to have the hdtv on.as it shows on that screen.not my monitor,:confused:
Try to connect your monitor to the DVI #1 (with DVI -> VGA Dongle) and your Hdtv to DVI #2 of your graphic cards.
