How to Calibrate the VP201B?
swinchen
Hi All.
What is a good, effective method for calibrating the VP201B? (Or any LCD for that matter) It didn't come with any special software or anything. I am looking for one of those software packages that says "match up the reds until they look the same" or something like that.
I have just been pushing buttons.... thanks.
Sam
First thing, are you running analog or digital inputs?
Analog you can do most everything with your buttons. I don't have the addy handy but type "monitor calibration" in google. That should take you too a few programs or sites you can use.
First and most important is your grey scale. Do your color after that.
If you can't find the instructions with the test program let me know.
Luck
