How to Burn?
Carnival Forces
when you're burning an album you've converted to mp3's, should you include the .m3u (i think that's the playlist) file?
this is being burned for listening on an mp3 portable cd-player.
It depends on your player. The two that I've got experience with won't play them, but you can throw them on the CD for completeness if you wish. [you can also throw in album art, text files, whatever, the player will ignore the other stuff]
thanks!
Which player are you using? My Sony D-Cj01 doesn't support .m3u files, but all the new IRiver ones do,IIRC.
