thought id post it. im not the author.
How To Build A Tin Can Waveguide Antenna...
http://www.turnpoint.net/wireless/cantennahowto.html
id be interested gee.Originally posted by gee
I'd like to build one of these, and put it on an impedance analyzer at work - there's no way one of these pringles antennas has a 1:1 SWR
I once made a 7-element Yagi on a printed circuit board for a friend, and the range was absolutely incredible. I should post some details on how to do it, because you can really easily make one by using copper tape and a sheet of plastic instead of an etched or milled PCB.
Yeah, and I bet you are one of those people who won't hold a GSM cell phone to their ear, too.Originally posted by Vertigo Acid
Just a thought: When the power of wifi is being dissapated omni-directionaly, the power density at a certain point away from the antenna won't be very high. But, when you funnel all that energy directionally... Well, you see where i'm going. 2.45ghz = resonence frequency of water = bad for the body. Don't go staring straight down one of these
