CrimandEvil
Dick with a heart of gold
- Oct 22, 2003
All 550 based cards are made equal, ATI's just cost the most and has the most useless junk.compwarez said:ATI TV Wonder Elite PCI
The Fusion 5 is the updated model.Dvico FusionHDTV3 Gold QAM
Fusion 5 Lite PCI HDtv tuner card
Apples and oranges son, you're comparing an SD tuner to an HD tuner. Also since you're using MCE if you went with the HD tuner you'll still have to get an SD tuner for it to work. In MCE HD support is simply an add on because the core PVR app is centered around SD content still.which one is better?
Then you'll have to use svideo out to the tuner card, in that case get a 550 based card because it does better processing on analog inputted content then the PVR150.I have Directtv box right now.
