How to adjust fan speed?
CR2500
I bought a cheap CoolerMaster 120mm case fan, and it does the job, but is the loudest fan in my case. How do I lower the voltage from 12V to 7V, or even adjust the RPM? It's connected directly to the P5K Deluxe.
Thanks.
Couldn't he just swap the 5v and 12v grounds on the molex? I remember doing this years ago or is there an unforseen problem with this?
