undertheradar
- Oct 26, 2004
Okay, here's the story:
I was playing COD4, and my system froze. Upon startup, windows couldnt start either then...odd. So I tried 'safe mode', and it still froze when loading 'Mup'.
So something in my windows system is toast. I dont have a floppy drive, so I never made an automated recovery disk, which might help in this case, but I tried this:
I figured I can just F-disk and start over (like I usually do every 6-9 months), but I want to pull all the data off of that drive. So I 'hot swapped' it onto another computer: I booted another SATA drive computer's windows system, and then plugged in the drive from the system that crashed.
Hey, it worked... or so I thought. The drive showed up, and I started to get into the files. It wouldnt let me into my own documents and settings though, so I had to use 'search' to get into my files. Great... I can see all my files, and they are all still there. The problem is that I cant get into any of them because I didnt boot from the same drive... the 'permissions' of an NT file system must mean I cant get into the data on the crapped out drive. What can I do to get around this? Is there some way to allow access to these files, or am I going to need someone I know to rip apart this drive with some expensive software?
To make matters worse, I tried hooking up the drive back to the old computer to see what, if anything might have changed. Now, the hard drive isnt even recognized as a system disk (but it does still show up on the other computer, so its still there). So I dont think ASR is even possible at this point... or is it?
