How this for my first overclocked system?
Mabrito
Well for the past couple weeks since I got my Scythe Ninja I have been messing with overclocks on my P4 system. I was able to get it to a 268FSB with some voltage increases. I dont feel like going over 1.5volts to possibly get it a tab bit higher. Its Prime95 stable. Ran it for 32 hours just fine. Here is a pick of CPU-Z and the Abit uGuru application:
http://img.photobucket.com/albums/v699/mabritoj/overclock.jpg
Right now I am messing with my BFG 7900GT. Right now with out a volt mod, im at a 535MHz core and the memory is at 750MHz. Its cooled by a Zalman VF-700. It idles at 40 and loads at 48-50.
My CPU loads at 54. Any opnions and suggestions are always welcomed.
Also, the memory divider is at 1:1 right now also. Its DDR2 667 ram im using. Im still learning how the dividers work so once I get a good understanding I will try my best to get it close to DDR2 667 speeds. Any help in this area would be greatly appreciated.
Asian Dub Foundation said:
definetly not bad! good job. ninjas are a beast arent they
OMG yeah they are. I mean I have a P4 and those temps are amazing. Im very very impressed with it.
I guess you are kinda implying that you plan on doing a volt mod on your 7900 no? If you do decide to do so, make sure to put a good little heatsink on the "trouble" spot. I think that it is a VRM or something, but I do know they get VERY hot and can cause some problems. Just a heads up.
Nah, I dont plan on it. I was just stating I didnt volt mod the 7900GT because volt modding a 7900GT seems like it is a popular thing to do to the 7900GT.
Dammm...what kind of number are yu getting with the puppy...
Did you do nay testing yet..quake/fear??
